Hello all, i am using Axure RP 9, and I want to add external javascript graph (the graph is wrote by d3.js) in Axure. Does anyone know how to add an external javascript graph in Axure? Thank you.
Hi IvyWang,
While the javascript graph can’t be added directly onto the Axure RP canvas, there are a few things you can try that should help. Linking to it via an inline frame may work as these widgets allow you to show external content in the prototype, but otherwise for adding external code to a prototype we would recommend publishing the project to Axure Cloud and then using the Plugins feature to add that code to your published project. Hopefully that helps!
Thanks. I will try the inline frame.
