Stay up to date on the latest beta channel builds of Axure RP 10 in this thread! Please keep in mind that the downloads mentioned here are for beta builds that are still in testing. If you run into any bugs or unexpected behavior, please report them to support@axure.com.
The latest stable build of Axure RP will remain available on our Axure Download page.
Download at Axure | Release Candidate or via Help > Check for Updates (with “Include beta channel builds” selected) in RP 10.
Axure RP 10.0.0.3827
- Improved indication for selection, editing, and hover on dynamic panels
- Use single key shortcuts to draw widgets in a dynamic panel’s all states view
- Link to keyboard shortcuts in RP is available via Help > Keyboard Shortcuts
- Fixed extra padding appearing on radio buttons and checkboxes in the HTML
- Fixed incorrect cursor x,y values in the HTML on Windows touchscreen devices
- Fixed very large images appearing blurry on the canvas on Windows
- Fixed very large pages appearing blurry in screenshots of Word specifications on Windows
Axure RP 10.0.0.3828
- Fixed dynamic panel toolbar disappearing on mouse over if canvas zoom isn’t 100%
Axure RP 10.0.0.3829
- Improved memory handling working with images on Windows
- Fixed option for Set Selected/Set Error interactions resetting when changing target widget
- Fixed selecting a checkbox or radio button in a group/panel set to toggle its selected state
- Fixed issues selecting some radio buttons in the RP UI
- Fixed issue with Google Translate automatically translating non-English prototypes in Chrome
Axure RP 10.0.0.3830
- Improved memory handling when working with large images in RP
- Improved performance loading preview in the browser
- Added preset desktop sizes to the web options of page dimensions
- Fixed errors and bad rendering after multiple resizes of the Interactions pane on Windows
- Fixed errors undoing a change to pasted multi-line text on Windows
- Fixed “Enable Single Key Shortcuts” preference resetting after updating RP
Axure RP 10.0.0.3835
- Fixed a memory leak opening and closing files on Mac
- Fixed hard crash on Mac when loading libraries with 1000+ widgets nested in a folder
- Fixed issue updating the widget style of some widgets in the Default library
- Fixed some SVGs importing into RP as white boxes on Windows
- Fixed incorrect links inside dynamic panels after duplicating a branch of pages
Axure RP 10.0.0.3836
- Fixed ability to select Keep in front checkbox in dynamic panel Pin to Browser dialog
- Fixed adding a new panel state via the context menu of the Outline pane
Axure RP 10.0.0.3838
- Ruler now shows a selection color whenever widgets are selected on the canvas
- Improved performance scrolling in the interactions pane with lots of show/hide interactions
- Fixed dynamic panel state name moving when editing it while zoomed in all states view
- Fixed issue adding widget to selection with Shift + Click if widget is on top of selected panel
- Fixed issue using spaces when searching prototype page names in the HTML
- Fixed adaptive views not changing in the HTML if page names include non-Latin characters
- Fixed issue selecting page guides immediately after adding them
Axure RP 10.0.0.3840
- Fixed a memory leak from opening legacy RP files
- Fixed memory leaks for non-modal dialogs
- Fixed memory leak generating Word Docs with screenshots of very large pages or widgets
- Fixed error reopening the Check for Updates dialog after closing it
- Fixed scroll to widget action not firing on a Panel State Changed event in the HTML
- Fixed SVG fills on rounded shapes losing transparency when published to Cloud
- Fixed context menu not showing on panes placed on external monitor
- Fixed issue preventing a new file from opening on Mac while the Cloud publishing notification is open
Axure RP 10.0.0.3841
- Prevented error adding text link to a text block with line breaks on Windows
- Fixed issue with bullet alignment when changing text line spacing on Windows
Axure RP 10.0.0.3842
- Easily create and apply a new style from a selected widget via the Style pane
- Fixed image overrides of SVGs not working on components in the HTML
- Fixed errors or hard crash adding a square 28px image as an icon in a widget library
- Fixed error using copy shortcut while focus is on repeater dataset
- Fixed connectors reflowing incorrectly after moving selection of connected widgets
- Fixed issues with connectors reflowing incorrectly after deleting connected widgets
- Fixed text not aligning correctly after moving a straight connector
- Fixed long click event firing on disabled widgets in the HTML
- Fixed issue viewing list items in the HTML when using light text color on a droplist on Windows
- Fixed issues resizing with non-left anchors on shapes with shadows in the HTML
- Fixed issue using a font with an apostrophe in its name in the HTML
- Fixed moving a pin to browser panel on window scroll on iOS
Axure RP 10.0.0.3844
- Fixed issue using multiple typefaces or font families on a text widget in the HTML
- Fixed issue changing some font style properties via set rich text action in the HTML
Axure RP 10.0.0.3847
- Fixed errors interacting with Library pane while a library is refreshing
- Fixed an error moving or undoing changes to overlapping connectors
- Fixed connectors breaking when moving them outside of a dynamic panel
- Fixed connectors reflowing incorrectly when converting them into a dynamic panel
- Fixed time, date, and month text fields storing input as hint text in the HTML
- Fixed issue preventing typing into a date text field with hint style in the HTML
Axure RP 10.0.0.3848
- ‘Fit to Text’ widgets inside Components now automatically adjust to override text
- Selection of Show All button for properties in the Interactions pane persists across widgets
- Improved memory usage while zooming and scrolling the canvas on Apple Silicon Macs
- Fixed errors opening a file on Windows if the current file used widget note fieldsets
- Fixed issues applying a widget style in the HTML if the style name includes a comma
Axure RP 10.0.0.3849
- Ctrl (Win) or Cmd (Mac) key allows for normal multi-select
- Ctrl+Alt (Win) or Cmd+Opt (Mac) shortcuts deep select widgets in groups or panels
- Ctrl+Alt+Shift (Win) or Cmd+Opt+Shift (Mac) multi-selects widgets in groups or across dynamic panel states
- Fixed widgets moving location upon conversion to a dynamic panel from inside a panel
- Fixed error closing out of publish dialog after deselecting pages to generate
- Fixed setting a variable to Cursor.x or Cursor.y values
- Fixed visual artifacts with connectors after undoing moves or deleting duplicate widgets
- Fixed arrowheads on straight connectors rendering incorrectly in the HTML
- Fixed MouseDown style effect not working without MouseOver effect on shapes in the HTML
- Fixed using Move event to re-enable disabled widgets in the HTML
Axure RP 10.0.0.3850
- Fixed error converting widgets with notes to a dynamic panel, repeater, or component
- Fixed widgets moving location upon conversion to a dynamic panel from inside a repeater
- Fixed issues with widgets in dynamic panels after converting the panel to a component
- Fixed issues with widget interactions after converting a widget to a dynamic panel
- Fixed issues with widget notes after dragging widgets into dynamic panels or repeaters
Axure RP 10.0.0.3851
- Fixed issue with right-aligned autofit text widgets shifting location in components on Windows
Axure RP 10.0.0.3852
FEATURE UPDATES
- Dynamic panel toolbar has an updated design and is now draggable
- All states view offers horizontal or vertical state layouts in addition to automatic layout
- Quickly enter the all states view of a selected panel with the Cmd+Enter (Mac) or Ctrl+Enter (Win) shortcut
- Switch states of a selected dynamic panel on the canvas using the [ or ] keys
- Cmd+Alt (Mac) or Ctrl+Alt (Win) to drag a widget from the library or canvas directly into a dynamic panel
- Single-click to exit panel when nothing is selected or double-click to exit if widget is selected
- Updated the masks for dynamic panels, repeaters, and components (turn off via View > Masks menu)
- Isolate button will temporarily hide other widgets on the canvas while editing a repeater
- When groups are selected, pasting will paste directly into the group
- Added visual drag handles and collapse/expand buttons to Panes
- Updated mobile device options for preset Page Dimensions
BUG FIXES
- Fixed nested hidden groups showing on the canvas after moving or copy and paste
- Fixed Alt key not showing distance guides when hovering over a dynamic panel
- Fixed global variable name changes not updating correctly in the prototype console
- Fixed repeater row actions changing from This to Rule after copy and paste
- Fixed simple repeater filters using [[TargetItem]] resetting to use [[Item]]
- Fixed Text Changed interaction not firing with stepper arrows on number text fields in the HTML
- Fixed radio button clearing selection after clicking a disabled button in the same radio group
- Fixed custom widget style names “selected”, “error”, or “disabled” conflicting with style effects in the HTML
Axure RP 10.0.0.3853
- The style toolbar is now dynamic and provides access to all widget specific style properties from the toolbar
- Slow clicking over a dynamic panel allows for selecting widgets behind the panel
