Download at Axure | Release Candidate or via Help > Check for Updates (with “Include beta channel builds” selected) in RP 10.
Axure RP 10.0.0.3855
- Upgraded to .NET 6 for improved performance
- Fixed changes to hint text not saving on text fields when the Interactions pane is undocked
- Fixed color dropper to allow selecting colors from different panel states in all states view
- Fixed widgets moving unexpectedly after dragging or copying them via the Outline pane in all states view
- Fixed hidden nested groups showing on the canvas while a hidden parent group is selected
- Fixed bug generating word specifications with spaces in file name on Windows
Axure RP 10.0.0.3856
- Fixed issues signing into Axure account when using a proxy
- Fixed error optimizing PNGs in RP
- Fixed crop and slice affecting wrong portion of images on MacOS Big Sur and Monterey
Axure RP 10.0.0.3859
- Fixed Libraries pane moving with mouse after adding widgets while it is undocked on Windows
- Fixed error pasting a selection including a locked dynamic panel with widget notes
Axure RP 10.0.0.3862
FEATURE UPDATES
Enhanced Duplicate: You can now duplicate widgets with consistent spacing.
- Widgets can be duplicated using [CTRL]/[CMD] + [D] or [CTRL]/[OPT] + Drag Selection.
- When duplicating a widget, RP will remember the distance you moved the duplicate widget from the original. Any subsequent duplications after that will place the selected widget the same distance until the widget is deselected.
- If you’re editing text during subsequent duplications, you will remain in text edit mode.
BUG FIXES
- Fixed duplicate image folders preventing all libraries from loading in RP
- Fixed errors when scrolling through or dragging from an updated widget library as it refreshes
- Fixed preserve corners distorting images when applied to widgets on MacOS 11 or 12
- Fixed connectors breaking when moving them outside of a dynamic panel
- Fixed connectors reflowing incorrectly when converting them into a dynamic panel
- Fixed hint text changing to input on text fields after using Back to previous page interaction
- Fixed issue setting size of widgets in repeater in the HTML via Item Loaded event
Axure RP 10.0.0.3863
- Fixed errors tabbing between component override fields in the Interactions pane
- Fixed errors when switching widget fills between solid and gradient
Axure RP 10.0.0.3864
- Fixed error converting to a component while a text link is currently selected on Windows
- Fixed issue dragging to resize a dynamic panel after converting widgets to panel
Axure RP 10.0.0.3866
- Quickly add sticky notes from the Insert menu in the toolbar or with the [M] shortcut
- Line color is now one of the default settings visible when configuring style effects
- Three-digit notation is now supported in hex code color input fields
- Fixed issue with Assistant font showing incorrect font weights in the HTML on Windows
Axure RP 10.0.0.3867
- Added common conditions in the Condition Builder for groups and hot spots
- Thumbnails for SVGs in image folders appear in the Library pane
- Notes are retained in the Publish to Cloud dialog after closing the dialog without publishing
- Fixed issues with files originally created in RP 7 and earlier and re-saved in build 3866
- Fixed flip animation on a dynamic panel state change causing the page to scroll to the top
- Fixed error copying page style properties after deleting style in the Page Style Manager dialog
Axure RP 10.0.0.3869
FEATURE UPDATES
- New share link option in the publishing confirmation dialog offers a default view of comments and additional pages of your prototype for easy stakeholder feedback
- Updated and refreshed UI style applied to the local prototype player in preview and generated HTML
BUG FIXES
- Fixed error pressing enter from the generators dialog with nothing selected
- Fixed SVGs showing a white background on the canvas on Mac
- Fixed issue moving multiple interactions at once when dragging them
- Fixed ability to edit case names while expanded in the Interactions pane
- Fixed dragging vertical scrollbars to scroll checked in team project pages on Windows
- Fixed push/pull actions from state change of dynamic panels pinned to center or right of browser
Axure RP 10.0.0.3870
FEATURE UPDATES
- Widget Snap Enhancement: Moving widgets on canvas will now snap to position when widgets are equal in distance.
- Easily upgrade team projects from RP 8 to RP 10 and keep the same Axure Cloud prototype link by opening the RP 8 team file in 10 and choosing to upgrade
BUG FIXES
- Prevented errors or crashes after closing RP files on Apple Silicon Macs
- Fixed old widget outline still showing on the canvas after intersecting multiple widgets
Axure RP 10.0.0.3871
FEATURE UPDATES
- Visibility of grid and guides can now be toggled in the Preferences dialog
- Set grid size as low as 4px in the Preferences dialog
BUG FIXES
- Fixed errors after pressing Escape key while adding a set adaptive view interaction
- Fixed ability to drag actions to an empty event in the Interactions pane
- Fixed pushing widgets below when showing a pinned dynamic panel in the HTML
Axure RP 10.0.0.3874
FEATURE UPDATES
- Full text values are visible in the Interactions pane when used in conditions
- More text is visible in the Interactions pane when showing long set text interactions
- Easily duplicate interactions with the [Cmd]/[Ctrl]+[D] shortcut in the Interactions pane
BUG FIXES
- Fixed an error moving or undoing changes to overlapping connectors
- Fixed alignment snap guides appearing incorrectly when equal distance snapping takes effect
Axure RP 10.0.0.3876
FEATURE UPDATES
- Widget Snap will prefer showing equal distance guides for widgets closer to the dragged widget.
Console Improvements:
- Trace automatically starts when the console pane is expanded for the first time in previewed files
- Console trace indicates when no conditions on an event are being met in preview
- Repeating interactions are grouped together in the console trace
BUG FIXES
- Prevented UI panes from accidentally undocking too easily
- Fixed issue using set opacity action to target a group in the HTML
- Fixed repeater column names not updating correctly in add sort action after editing the column name
- Fixed incorrect fill size on autofit text in the HTML when using style effects to adjust font size or weight
- Fixed Loaded event on repeaters preventing any other loaded events from showing in the console trace
- Fixed repeater Item Loaded interactions appearing in the wrong part of the console trace
Axure RP 10.0.0.3877
FEATURE UPDATES
- New prototyping templates: Select from 3 new templates to jumpstart your next project
- New Prototyping Basics file available from the Welcome Screen and Help menu to help new users learn the basics of RP with hands-on exercises
- Form widgets added via Insert menu match the styling and style effects of forms from the Default library
- Currently selected color is used as the first color stop when switching from solid to gradient in the color picker
BUG FIXES
- Fixed scale to width in prototype player for auto sized pages with widgets in negative regions
- Fixed the error loading dialog not showing when opening corrupted files in RP
- Fixed widgets being removed from component when breaking away the parent dynamic panel state
Axure RP 10.0.0.3878
FEATURE UPDATES
- Paste to replace widgets on the canvas using Ctrl+Alt+Shift+V(Win) and Cmd+Opt+Shift+V (Mac).
- Image fill selector includes button to paste image currently on clipboard
BUG FIXES
- Fixed bugs where widgets with resizing constraints move or resize unexpectedly when resizing their group
Axure RP 10.0.0.3879
FEATURE UPDATES
- Common events appear at the top of the Events list when adding interactions to form widgets
- New buttons make it easy to toggle cases between If and Else If in the Interactions pane
- Folders that do not include the currently selected page are now collapsed by default in the sitemap of the prototype player
BUG FIXES
- Fixed style effect font color of selected checkboxes not showing on load in the HTML
- Fixed disabled styles not showing for widgets in dynamic panels nested in a disabled group
- Fixed using “My folder” when running a checked out generator in a team project
- Fixed pinned RP shortcut icon breaking in the Windows taskbar after running the build updater
Axure RP 10.0.0.3880
FEATURE UPDATES
- Adding a new condition to a Key Up or Down event defaults to the key pressed condition
BUG FIXES
- Fixed lightbox background not showing on mobile devices when used inside a component
- Fixed opacity slider not moving to 100% in color pickers on Windows
- Fixed text cursor not showing in the Edit Rich Text dialog from dark mode on Mac
Axure RP 10.0.0.3882
FEATURE UPDATES
- New ability to share files and get help from Axure Support by publishing to Axure Cloud from the Contact Support dialog
- Updated design of Color Picker to show that it can be moved
BUG FIXES
- Fixed style effect line color of selected checkbox/radio button not showing with color picker
- Fixed icon alignment for Update/Create style button
- Fixed padding on sitemap button in prototype player
Axure RP 10.0.0.3883
FEATURE UPDATES
- New ability to define the shift nudge distance in the Preferences dialog
- Workspace icons updated in the Publish to Cloud dialog
- New ability to enable share links for team projects directly from RP
- Team project link URLs are now visible after sending all changes through the Publish to Cloud dialog
BUG FIXES
- Fixed error undoing changes to panel state names in the panel state selector
- Fixed page selection appearing enabled in team project generators that are not currently checked out
Axure RP 10.0.0.3885
FEATURE UPDATES
Dynamic Panel Updates:
- Copy and paste states in and out of dynamic panels
- Reorder dynamic panel states while in all states view
Interaction Editor Updates:
- Dynamic panel states dropdown now automatically opens when configuring a Set Panel State action
- Event list now automatically opens when a target widget is selected using the Fire Events action
- Push/pull distance shows in the Interactions pane when a distance for the show/hide interaction is set
- Upgrade your RP 8 and RP 9 team projects by opening them from the Get Team Project dialog
- Shift nudges will snap to the grid when widgets pass a grid point (if Snap to Grid is enabled)
BUG FIXES
- Fixed Check for Updates dialog continually loading when checking for updates
- Fixed Axure RP 10 freezing on launch when activated with a site.key through silent installation
- Fixed image fill button displaying as gray when filled with an SVG
- Fixed text cursor jumping to the front when inputting large numbers or when using math calculations for X,Y,W,H values
- Fixed text cursor misplacement when using search in the Pages, Library, and Components panes on Windows
- Fixed shift nudge changes not being applied until Axure RP is rerun
- Fixed shift nudge setting not being utilized when snap to grid is enabled
