Axure RP 10 Beta Channel (Release Candidate) Updates
#41
Download at Axure | Release Candidate or via Help > Check for Updates (with “Include beta channel builds” selected) in RP 10.
Axure RP 10.0.0.3886
FEATURE UPDATES
Dynamic Panel Updates:
  • Use [Cmd]+[Option]/[Ctrl]+[Alt] while resizing a Dynamic Panel or Group to ignore widget resizing constraints
  • New top bar in All States View allows renaming Dynamic Panels and managing panel states
Interaction Editor Updates:
  • Added a button in the target drop list to scroll to the current dynamic panel state
  • New keyboard shortcut to create hyperlinks [Cmd]/[Ctrl]+[K]
Outline Pane Updates:
  • Duplicated Groups, Folders, and Dynamic Panels will retain their expanded/collapsed states
  • Added a filter to show widgets with interactions
More Updates:
  • Lock and Unlock Location and Size commands combined into one toggle command [Cmd]/[Ctrl]+[Shift]+[K]
BUG FIXES
  • Fixed library drop list search filter not returning results
  • Fixed edit location and size keyboard shortcut error when location field is hidden in the overflow menu
  • Fixed errors around duplicating Dynamic Panels
  • Fixed Dynamic Panel tooltips appearing on screen after using keyboard shortcuts on Mac
  • Fixed focus switching to Outline pane when renaming states in All States View
  • Fixed hard line break error when adding hyperlinked text and non-hyperlinked text within the same widget
  • Fixed slow pinch to zoom issue on Chrome/Edge on Macs
  • Fixed issue with Has Name filter not appearing in the Outline pane after changing widget name
#42
Axure RP 10.0.0.3887
FEATURE UPDATES
  • Added ability to rearrange targets within an action in the Interactions pane
  • Added back/forward buttons in the Tab bar to easily navigate between recently accessed pages and Components
  • Added option to expand or collapse all pages/folders in the prototype player
BUG FIXES
  • Fixed loading Axure RP 8 libraries
  • Fixed “Has Name” filter when targeting a widget in the Condition Builder
  • Fixed “Has Name” filter showing text widgets without user added names
  • Fixed Edit Many icon color in droplist widget in dark mode
  • Fixed order rendering when resizing a Group in a Dynamic Panel
  • Fixed panes collapsing when double-clicking into an area of the pane
  • Adding a new state to a panel in the Outline pane will automatically expand the panel and show that state
#43
Axure RP 10.0.0.3888
FEATURE UPDATES
  • Added ability to duplicate using [Cmd]/[Ctrl] + [D] when focus is in the Outline pane
  • Added an expand/collapse all button in the Outline pane
BUG FIXES
  • Fixed RP 8 showing as all versions when replacing a project
  • Fixed focus not being set in font droplist when using [Cmd]/[Ctrl] + [T]
  • Fixed selection not being set on panel state when adding a new state through the Outline pane
  • Fixed error using [Cmd]/[Ctrl] + [C] in Outline with page name selected
  • Fixed widgets pasting into the negative region of an empty panel state
#44
Axure RP 10.0.0.3889
FEATURE UPDATES
  • Image optimization improvements
  • Target selection border on the canvas now appears immediately when opening the target selection droplist
  • Added new button to open a project page in Axure RP when an Open Link interaction targets that page
  • Added new button to select widgets that are targeted by an interaction
  • Added new [`] single key shortcut to easily toggle between selection modes
BUG FIXES
  • Fixed error when working with pasted images on Mac
  • Fixed undo/redo not working when fill selector is open on Windows
  • Fixed error deleting a page when two or more page tabs were open
  • Fixed error when leaving panel state name field blank on Mac
  • Fixed error undoing creation of Dynamic Panel with states menu open on Mac
  • Fixed error adding a state in All States View while Outline pane is hidden on Windows
  • Fixed Dynamic Panel getting into a bad state after adding a state with Outline pane hidden in All States View
  • Fixed Dynamic Panel name field appearing offset when viewing all states and working with different zoom settings
  • Fixed Dynamic Panel states appearing out of view when duplicating states and viewing all states for the first time
  • Fixed animation type not being displayed in Interactions pane for Set Opacity action
#45
Axure RP 10.0.0.3890
FEATURE UPDATES
  • New help link for working with interactions for all users
  • Updated empty state of Condition Builder
BUG FIXES
  • Fixed screenshots on Mac pasting at larger sizes
  • Fixed error using Select and Manage tabs dropdown to select page not visible in opened page tabs
  • Fixed error closing Axure RP when text editor still has focus after renaming cases
  • Fixed widget size reporting incorrectly when working with text overrides and Components
  • Fixed library tooltip not scrolling in Interactions pane for widget libraries
  • Fixed single key shortcut tooltips updating inconsistently when enabling/disabling them
  • Fixed fill selector not updating when undoing a fill change in Style pane
  • Fixed crop area resetting when panning on canvas using [Space]
  • Fixed pages getting deleted after adding a Component and then undoing the add
  • Fixed error when republishing a file with a special character on Mac
  • Fixed text cursor landing in errant position when working with multiple lines of text in text editor on Mac
#46
Axure RP 10.0.0.3891
FEATURE UPDATES
  • Added context menu option to optimize fill images for shape widgets
  • Dynamic Panel states now show thumbnail previews on hover when configuring Set Panel State interactions
  • Added the option to Open New Window from the file menu or taskbar (Windows only)
BUG FIXES
  • Fixed issue with interactions not working in preview when Component is on the page
  • Fixed issue with blank page appearing in preview when page contains Dynamic Panel with Component overrides
  • Fixed issues with push/pull working incorrectly in some file setups
  • Fixed issue where deleting an interaction in the Interaction Editor dialog deleted all interactions
  • Fixed target button selecting the Group when interaction is targeting the widget inside the Group
  • Fixed Component overrides defaulting to original text widget, rather than the override text
  • Fixed [Cmd] + [X] deleting Dynamic Panel when working in floating panel menu
  • Fixed Back In History button getting enabled after removing the page from page tabs
  • Toggling visibility of panes now retains their collapsed/expanded states
  • Fixed issue with text input field not appearing when switching from “is” to “equals” in the Condition Builder
  • Fixed snap to grid working incorrectly when widget is placed at an x,y position on the canvas less than the grid spacing value
#47
Axure RP 10.0.0.3892
FEATURE UPDATES
  • Easily access troubleshooting logs directly from the Help menu
BUG FIXES
  • Fixed global variables not persisting correctly across pages
  • Fixed Select Shape options in context menu not appearing
  • Fixed error with Submit Button dropdown in Interactions pane when using text field widgets
  • Fixed Delete Rows interaction not working when triggering it from a widget inside another Repeater
#48
Axure RP 10.0.0.3893
BUG FIXES
  • Fixed conditional interactions not working with Repeaters
  • Fixed error selecting Has Interactions filter when selecting a target widget
#49
Axure RP 10.0.0.3894
BUG FIXES
  • Fixed error deleting a state when Dynamic Panel is filtered out in the Outline
  • Fixed retaining mixed border visibility on shapes when importing using Figma plugin
#50
Axure RP 10.0.0.3895
BUG FIXES
  • Fixed issue with interactions not working in preview when Components containing Repeaters with overrides were on the page
  • Fixed child adaptive views not showing widgets in Component views when overrides were used
  • Fixed issue with Repeater [[Item]] interactions returning undefined
  • Fixed error deleting Dynamic Panel state containing a Repeater
  • Fixed error deleting Dynamic Panel state when bottom of the panel was not visible on the canvas
  • Fixed flip animation on a Dynamic Panel state change causing the page to scroll to the top
#51
Axure RP 10.0.0.3896
BUG FIXES
  • Fixed issue with interactions not working in locally generated HTML when using Inline Frames to target another page within the project
  • Fixed issue with Open Link interactions not working when navigating to a page within the project in locally generated HTML
  • Fixed exception opening link in frame to the current page
  • Fixed style effects not working to change font properties
  • Fixed hard crash on Macs when saving and exiting a widget library file before the widget library was updated
  • Reverted a change that enabled targeting repeater rows from within another repeater in order to improve repeater interactions
#52
Axure RP 10.0.0.3897
FEATURE UPDATES
Repeater Updates
  • Import multiple images at once via cell/column context menu
  • Paste multiple images/text from clipboard into multiple cells at once
  • Pasting onto a column header now pastes into the cells below
  • Added option to Paste with Column Names via the column context menu
  • Cut, copy, paste, and clear via the dataset context menu
  • Use [Cmd]/[Ctrl] + [A] to easily select all cells in dataset
  • Hold [Cmd]/[Ctrl] and click to select multiple non-adjacent columns/rows
  • Sort dataset via the column’s context menu
  • Drag to move multiple adjacent columns/rows in the dataset
  • Added option to optimize images after import via dataset context menu
  • Updated UI in the Add Row dialog
BUG FIXES
  • Fixed error when assigning a submit button through the context menu
  • Fixed incorrect resizing in style effects when Fit to Text Height with line spacing was applied on a widget
  • Fixed copy and paste from one panel state to another not maintaining position in All States View
  • Fixed Dynamic Panel in Groups flickering with Window Scrolled Up/Down interactions
  • Fixed push/pull scrolling page to the top when widgets were in a Group
  • Fixed extra row being added when copying and pasting data from Excel to a Repeater dataset on Windows
#53
Axure RP 10.0.0.3898
FEATURE UPDATES
Connector Updates
  • Single-click a connector point to add a new connector and matching shape
  • Use [Cmd]/[Ctrl] + [Opt]/[Alt] + [Shift] + [Arrow] to quickly add connector and shape to selected widget
  • Add new connector points along the edge of the starting or ending shape when drawing a connector
  • Ability to select the next shape when drawing a connector that doesn’t end on an existing shape
  • New connector point styling
More Updates
  • Updated sign in dialog when connecting to Axure Cloud for Business or OnPrem instances with SSO
  • Publishing a project with an access code will show updated public share links with the hashed access code embedded in the URL
BUG FIXES
  • Fixed error when holding [Shift] and selecting column header in Repeater dataset on Windows
  • Fixed all states of Dynamic Panel being visible in Preview when empty Repeater was on the page
