Hi Guys,
When I install the Axure program in Windows 11, I click on the installer but the program doesn’t give me any response, I checked the system configuration and .net framework 4 and still the same? What should I check so that I can install the application properly? What are the pre-requisites that are necessary to install Axure?
You’ll likely get a faster response by emailing your question directly to support@axure.com
