I’m getting a strange situation involving disabled radio buttons. Basically, they won’t actually disable.
They’ll follow the disabled style, but they’re still clickable (even if you won’t see it). Even worse, when I actually checked the disabled status in a running project, they didn’t show as disabled, even when I set them that way explicitly. I’ve also tried using a Loaded interaction with no luck.
Is this a known bug, or is there some trick to making these checkboxes respect the disabled setting? I’ve attached a test file to show what’s going on.ButtonsTest.rp (47.1 KB)
I’m new to Axure, so any help you can give would be very appreciated. Thanks!
