I’ve been having this issue where I copy my layout from Sketch (using the Axure Sketch plugin) and it pastes everything jumbled and spread out. Even copy pasting a few items from the design will yield the same result. E.g. Copying a row containing a text object, 2 circles, and 2 more text objects - Pasting into Axure drops the text objects all the way over to the left, one on top each other, and the circle objects all the way to the right, in a distance almost twice the width of the design. If I copy an entire layout and paste it, forget it. It’s impossible to work with as everything is as far apart as possible from where its original position with multiple objects jumbled on top of each other. So i’m relegated to pasting one item at a time if I want to use the plugin which makes the plugin useless for copying entire layouts. It used to work fine so this is really bizarre.
Exporting as SVG then converting to shapes works fine but I really got used to the efficiency of using the plugin. Is anyone else experiencing this?
