I am designing a layout with several panels that can be opened and resize, a bit like Visual Studio. Some characteristics:
- Menu on the left can be expanded (wide, icons + labels) or small (only icons). When its expanded, it compresses the middle part (but not the Side bar on the right).
- When you click a city in the map, a sidebar expands from the right. User can close this with or resize the width with a splitter.
- Middle has a bottom part that can be changed in height with a splitter.
- On certain conditions, the bottom part can be split in two.
Something like this:
(actually, the domain of the app is something completely different, but you get the layout idea)
I thought this would be an excellent thing to prototype with Axure, but (again) after hours of trying, I’m thinking this is simply undoable.
- The right sidebar needs to limit the side of the middle part. You cannot push/pull widgets here because that only works to the right. So I was manually resizing a middle 'Content Dynamic panel.
- But off course that panel has widgets and Axure does not support setting widths to a percentage of their container, so how would I do this? On the open of the side bar, re-size each and every widget on the Content panel?
- But when the bottom panel is in its split state, each of those widgets has a different size.
- And I have not even touched the subject of the splitters.
This layout is fairly straightforward, am I missing something?
