From reviewing your Axure RP projects, it looks like the Fire Event action is trying to trigger an OnClick event for your white rectangle, is this correct? I wanted to let you know that there is a known issue that our respective teams have on file regarding this behavior, where OnPageLoad events with a Fire Event action are set to target a widget’s OnClick action will not successfully fire that OnClick action. While this issue is still under investigation, I’ll be adding a note to our filed report regarding your experience.
I also wanted to confirm that in Axure RP 9, the console is only available when previewing your project locally.
