I have tried a way of highlighting a row in a repeater, which has a OnClick/OnMouseHover event. Hope this is usefull?
Idea:
Remove the background color within the repeater shapes, just a border is good enough. Add a rectangle to depict the highlighted row in the background of the repeater, make sure the height of the highlight shape is same as that of the row.
Onclick/OnMouseHover event move this Highlight.shape to x: highlight.x (basically whatever name.x)
similarly move the shape to y: [[item.index*h-h]] (where h is the highlight shapeâs height).
this is itâŚyour row highlight is ready. This code works in case the entire repeater and highlight are placed in Panel (attached is the sample depicting the same scenario).
If its in the root page, you need to offset the highlight y location i.e [[item.index.h+offset]] where offset will be the highlight shape y co-ordinates - height of the highlight.
RepeaterHighlight.rp (60.4 KB)
RepeaterHighlightInPage.rp (60.7 KB)
