Hi KavaKiwi,
Ah! Sorry for the confusion.
The “Available From Cloud” option is available when clicking on the library droplist, as you can see here:
Hi KavaKiwi,
I can’t load my library from cloud. Get the message “The library could not be loaded”. I don’t know why ?
Hi supertoket,
Yep! Team project widget libraries should be supported when Axure RP 9 is officially released.
Fron a user experience perspective, the location for “Available from Cloud” is in unexpected. I expected to find it under “Get libraries” flyout as well. How illogical of me… ; )
I am not seeing ‘AVAILABLE FROM CLOUD.’ I am logged in and have followed all the other procedures.
I also am not seeing available from Cloud. I just updated to the latest version and am also logged in.
Hi,
If you’re on the latest build (3642), are logged in to the Axure account that has your widget libraries, and don’t see “Available from Cloud” when opening the widget library search dropdown and scrolling to the bottom, then can you verify whether you’re currently unable to publish to the Axure Cloud via Axure RP, or if you happen to have any proxies or the like set up that may be preventing Axure RP from pinging <app.axure.cloud> to pull that library information?
Hi Alyssa,
Thank you for the suggestions. I have gone throgh the steps:
Thanks for that! To confirm, of the libraries that you have hosted on the Axure Cloud, have you already loaded them? The “Available from Cloud” section will show the libraries that are available on the cloud but have not yet been loaded into the Libraries pane. Once cloud libraries have been loaded, they will be removed from the “Available from Cloud” section and will instead show among your other local libraries with a cloud icon next to them:
If all of the libraries that you have hosted on your Axure account are already loaded, then the “Available from Cloud” section won’t be visible since there’s nothing to see. Does that sound like what you’re running into?
Hi Alyssa,
Yeah, since I created the libraries that is why they probably don’t show up, and why I never see “Available from Cloud.”
However, my colleague still does not see “Available from Cloud” and we are pulling from the same Axure Share location, and she has not loaded the library.
Hmm, interesting! By any chance do the libraries that you and your colleague are working on happen to be team project widget libraries (.rpteamlib extension for RP 9 and .rplibprj for RP 8)? If so, team project widget libraries are not yet supported in the Axure RP 9 widget libraries pane, so if those are the only widget library files that you currently have unloaded and available on the cloud then the “Available from Cloud” will not show up, but should show up if you publish regular widget library files (.rplib) to the cloud.
Ah, I am having same problem as Geoff, and to answer your question, for me yes, the only team file I have on Axure share is a team widget library. So, is there a way to add and utilize team widget library to a file, in RP9?
It was working for me on a previous computer, but I had created the team file from a local widget library file, so I suppose it was “already” loaded at that point, as you mentioned earlier. I was then able to use and edit the shared team widget library all from my Widget Library panel within any file. However, upon switching computers yesterday, I had to re-download Axure, re-add local libraries and fonts. And now I need to re-add that team library. Is there a workaround in RP9 for this?
To add to this - I tried adding the locally stored .rpteamlib file from local hard drive, as workaround, so I at least had the most current version of the team library, but Axure does not see / recognize the .rpteamlib file at all.
Hi,
Looks like you emailed your question to support as well, but to reiterate here you can create team widget library files in Axure RP 9 now that team projects are implemented, but currently team widget library files cannot be loaded manually and will not show in the “Available from Cloud” section of the Libraries pane as we’re still working on that aspect. This will work later, but for the time being you would need to export the team widget library to a non-team file via “File > Export Team Project to File” and then load that file instead.
I’m glad you see them now! As you’ve noticed, in build 3644 and onwards team libraries are now included in the Libraries pane; if you previously had only team libraries loaded on the cloud and weren’t seeing them in the “Available from Cloud” section, these (along with “Available from Cloud”) should now show after the update.
