I am trying to get a design built where a dollar amount can be calculated based upon a fixed starting price and the user can enter a percentage. For example, the starting price of one item is .25 Different items have a different starting price. I have a blank text field for a percent to be manually entered and once it is, I need it to fill in the new dollar amount in a different field.
I also need to reverse this process by entering a new dollar amount and the percentage auto-filling.
That is correct. I built a repeater with different items in it and each has a different base price. When you select an item from the repeater, it lists the base price for the item and allows the user to enter a number in the percent field which I want to appropriately update the new price field or enter a number into the new price field and have the percent field automatically update.
Hey @DCraig, are you trying to create something like that? Percent_repeater.rp (53.0 KB)
If it is not something you’re looking for, can you please tell us more about what should be added? Maybe you have a link where we can see a similar behavior?
It looks like you are real close to a working solution. …It wasn’t that easy to understand what’s going on here, so let’s see if this is correct…
The "AWP/UOM" column is the starting price of a medication–yes?
If user clicks a row’s “Details” button it shows the “Edit CW” group, as a kind of popup modal.
So the "Edit AWP UOM" widget is the starting price from that row, and user can change the markup, either in the "Edit Percent" text field, or "Edit dollar" text field.
…and the "New CW" group is not used, but maybe your attempt to test some things?
Because both fields are editable and either field changes the other, you don’t really want to use the Text Changed event of the text field, because you’d risk a never-ending loop or inaccuracies due to rounding errors.
I duplicated your Pharmacy Pricing page and made changes there.
I moved the “New CW” group down and unhid the “Edit CW” group to make it easier to work with.
I added a Loaded event to this group with “Hide This” action. I find this much easier to see and change things versus unhiding or clicking into things to see what they are.
I added an Update button for each Mark-up field.
Set up a selection group and selected style for these buttons.
For each text field I assigned the associated Update button as the Submit Button.
Fire the Update button’s Click or Tap upon Lost Focus (so a Tab or click away from the text field will update the other field.)
(You can hide these Update buttons if you don’t like the look/clutter, and things will still work the same.)
Here are the algorithms I use for each Update button:
// where_BASE = text on “Edit AWP UOM” ; PERCENT = text on “Edit Percent” ;
DOLLAR = text on “Edit Dollar” …and .toFixed(n) is a built-in function that forces rounding to specified decimals
For the Save button, your Edit Row Data action works, I just cleaned it up a bit.
I removed the AWP/UOM column because that never changes.
I also updated the names of [[LVAR1]] local variables to make things more readable.
You don’t need to change selection states for widgets in the repeater because when you edit row data it rebuilds the repeater, resetting all widgets to default states.
For good measure, I added a Set Text to update the "Last Modified" line and a brief Wait before hiding the popup.
Awesome, thank you! I re-worked it a bit so the Update buttons would not be necessary and it works. I had the wrong formulas, though. I really appreciate the time and effort you put into this to help me.
