Hello there,
I am working on a project where I need to use dynamic panels to navigate between different pages within my prototype. The concept is straightforward, but I have encountered a challenge that I cannot seem to figure out.
I have set up a dynamic panel with multiple states, and each state corresponds to a different screen that should appear when navigating through the prototype. Although; when I try to use interaction triggers like On Click or On Mouse Over to switch between the states of the dynamic panel, the transition is not smooth or consistent. It works intermittently, and sometimes the panel does not switch at all.
I have ensured that the interactions are set up properly for the dynamic panel, and I am using the standard Set Panel State action. But I am wondering if there is a specific step I might be missing or something I need to adjust in the settings. Also; are there any best practices for ensuring a fluid transition between states that I should be following?
Also, I have gone through this post; https://forum.axure.com/t/assistance-required-in-axure-rp-10-for-conditional-logic-and-dynamic-panels-devops which definitely helped me out a lot.
Additionally; I am not sure whether I should be using the Go to Page action instead for a more straightforward navigation between different pages, or if there’s a better approach that integrates well with dynamic panels for this kind of use case.
Thank you so much in advance for your help and assistance.
