Hi, I have a file updated in RP 10 and and I’m not able to open and use it in RP 9. I have only RP 9 license. Can you please let me know if it is possible to open the file in RP 9?
Nope. Axure is backwards compatible only. If original author has both 10 and 9 they should be able to port it. Otherwise, you could try the limited-time trial version of 10 to open it and try converting to 9.
Thank you for your response mbc66. Do you have any tips or share any useful source to refer for RP 10 to RP 9 transition?
