So I’m mocking up a webstore with lots of moving parts. I’ve been trying to figure out how to move rows between repeaters. I’ve successfully been able to copy rows from Repeater 1 to Repeater 2 with a button. My next goal is to do the same from Repeater 3 into Repeater 2. In the end, I would need to show items added from Repeater 1 and Repeater 3 simultaneously in Repeater 2. I started out doing what I thought would work, but it seems like there’s some sort of conflict. I’m not familiar enough with Axure to figure out what that might be though. Any help would be greatly appreciated!
I have my Axure file attached. There’s a lot going on, but the parts involved in this issue are all on the “Mixes/Cart/Custom Name” page.
It’s hard for me to tell but, because you’re using Page Loads to trigger what dynamic panel state to switch to you’re resetting the repeaters back to their original state, is if someone was going to the page for the very first time.
You have the logic to add a row to the “Cart” repeater from the “Mixes” repeater and that works. You can see it if you switch to the Cart panel without refreshing the page. If you want to populate the “Cart” repeater, you need to have some logic to add it. EX:
PAGE LOADED If value of "ItemsInCart" does not equal "" Add Rows "Cart Repeater"
and then use what ever global variables you want to populate the row.
You’re a genius!! My professor and I were both under the assumption that I should have any issues with 3 repeaters, and this explains so much. Thank you!!
If you start feeling adventurous, there’s some threads on the forum about people wanting to do some pretty elaborate stuff with the “shopping cart” concept.
