Download 3634 for Mac | Download 3634 for Windows
Axure RP 9.0.0.3634
- Restored slow click to select widgets behind each other
- Fixed error using shortcut to set opacity of multiple widgets
- Fixed issues inputting negative values for shadow offsets
- Fixed error using pen tool inside repeaters that set widgets to selected or enabled
- Fixed OnWindowScroll interactions on iOS
- Fixed some interactions not working on iOS after changing panel states with animation
- Fixed an issue converting version 8 files with gradients on grayscale pages
Download 3635 for Mac | Download 3635 for Windows
Axure RP 9.0.0.3635
- Added Interaction Editor dialog for advanced interaction editing
- Simplified editing interactions in Interactions pane and removed condensed mode
- Changes to connector mode controls
- Improved scrolling of dynamic panels on iOS
- Fixed errors copying table cells containing text links
- Fixed some issues importing from or converting 8 files with adaptive views to 9 files
- Fixed master views not showing in snapshot widgets
- Fixed ability to use pan and zoom mode on snapshot widgets
- Fixed ability to change size of checkboxes and radio buttons on Mac
- Fixed style effects not working inside panels containing checkboxes and radio buttons
- Fixed widget notes inside an inline frame appearing blank in the HTML
- Fixed issues moving and getting coordinates of pinned panels in the HTML
- Fixed scrolling horizontally to widgets inside dynamic panels in the HTML
- Fixed issue showing checkboxes and radio buttons as selected and disabled in the HTML
- Fixed issue getting repeater height in the HTML
Download 3636 for Mac | Download 3636 for Windows
Axure RP 9.0.0.3636
- Widget name is visible at the top of the Style pane
- Console trace can capture OnLoad events after a page refresh in the HTML
- Fixed errors adding inner shadows to open custom shapes
- Fixed error opening Interaction Editor with multiple widgets selected
- Fixed errors working with the Interactions pane on Windows touchscreen machines
- Fixed order of library names when All Libraries is selected
- Fixed issues using non-English language keyboards or characters while editing text
- Fixed issues with the Edit Many dialog for droplists and listboxes
- Fixed issues with visibility and master views in nested masters in the HTML
- Fixed rendering issues when resizing a widget beyond the canvas dimensions
- Fixed rendering issues after toggling side panes on Windows
- Fixed dialog and popup locations when Windows taskbar is not placed at bottom of screen
Download 3641 for Mac | Download 3641 for Windows
Axure RP 9.0.0.3641
- Team projects now available in RP 9
- Can use conditional logic to check current master view from inside a master
- Fixed corrupted libraries preventing other libraries from loading
- Fixed RP getting sent behind other applications after opening dialogs and popups on Windows
- Fixed issue with large text not showing on text field widgets on Windows
- Fixed hidden masters in repeaters appearing in the HTML
Download 3642 for Mac | Download 3642 for Windows
Axure RP 9.0.0.3642
- Optimized scrolling and moving around the canvas on Mac
- Optimized performance working with images using filters
- Updated device listing under Page Dimensions
- Breaking away masters with overrides keeps the overrides in place
- RP 8 widgets with different shape and text rotation will convert with correct rotation in RP 9
- Fixed error using “Edit Library” menu option on Windows
- Fixed errors interacting with tabs after closing page or master
- Fixed some text alignment issues when overriding text on masters
- Fixed master views not showing in repeaters
- Fixed data not showing after duplicating a panel state containing a repeater
- Fixed first keystroke not beginning edit of repeater data on Mac
- Fixed error adding shadows to very large widgets
- Fixed using a condition to check if a text field is disabled
- Fixed horizontal scroll issues on iOS prototypes
Axure RP 9.0.0.3645
- Fixed errors working in file after adding an open link interaction
Download at Download Beta | Axure or via Help > Check for Updates in RP
Axure RP 9.0.0.3646
- Fixed issues editing links from legacy files
Further release notes for Axure RP 9 can be found at www.axure.com/release-history
