I have a dynamic panel in my repeater set to hidden that I want to show based on a column in the data for the repeater. How would I go about that?
Show Dynamic Panel Based on Column Value in Repeater
mbc66
#2
In the repeater’s Item Loaded event, add a case to test the value of your column value. So, if your column is named, “DP” and if it has value of “true” the panel should be shown, then your case logic would be something like, “IF [[Item.DP]] equals “true” Show MyDynamicPanel”. Then of course you just need to update the repeater row(s) to hide /show specific row’s dynamic panel.
system
closed
#3
