Hi
When I select some text and changed it to “Letter case” in the Text Decoration box, I see that the case has been changed correctly to uppercase with whatever decoration, however, it indents it with a bullet point.
Hi @brianjrosen, can you please attach a copy of your .rp file so we can take a closer look at the issue? I’ve tested by following the steps you described, but I could not reproduce this behavior, so your sample file would be very helpful!
You’re probably right! I’ll check it out- the “select” state on that overlay is a bit light, so perhaps I didn’t notice it. Thanks,
