Hi !
I am unable to select (with drag and drop) grouped items with the “contains” selection mode.
Here is a quick gif
Thanks !
Hi !
Here is a quick gif
Thanks !
Hi madorus!
There’s a known issue regarding this behavior on file that our teams are currently investigating. While this issue appears to occur while in “Select Contained” mode, we’ve found that switching to “Select Intersected” mode helps to work around the issue. I’ve gone ahead and added a note to our filed report about your experience with this issue, and I hope that the workaround helps in the meantime!
Thank you for your feedback !
I will call out that using the intersected mode is actually NOT a workaround. When I have a pile of widgets, I NEED the contains mode to get the right thing. This bug needs to be prioritized.
Hi all,
The fix for “Select Contained” mode not allowing groups to be selected on the canvas has been included in the latest release candidate build, 3665. You can download it and review the release candidate release notes on the beta channel thread here. Hopefully that does the trick!
