I feel like i’m missing something super obvious, and I’ve been looking at this too long, or I found a bug?
I have a more complex project I’m working in, but I reproduced the issue in a simple example. I have a repeater widget and I need to delete a specific row when the user clicks a button. The repeater has only 3 values. NY, CA, and FL. I added a interaction on the button to delete the row where item.state matched ‘CA’ and nothing happens.
However, if I add a text box, and put the text CA in the text box, then ask the repeater to delete the row where item.state matches a local variable set to the text in the text box it works. This makes no sense right?
The file is attached and I added a screen shot of the setup.
FilterTest.rp (55.3 KB)
