Start typing some text on your keyboard Result:
Your typing has no effect Expected Result:
As per previous versions, the selected item (in this case the label text) should switch into text edit mode and accept the text you are typing. The same interaction applies to any object that can accept text, including buttons, shapes, etc.
I don’t know if you have the latest build. But I saw something in the release notes that mentioned this being fixed. I tried it and it’s working for me.
That is, you can now click-drag to produce a shape after clicking on any of the mentioned shortcut keys:
R – rectangle mode
O – oval / ellipse / circle mode
T – text mode (drag to dynamically fill area with example text)
P – pen drawing mode
L – line mode
One additional thing that may help is hitting [enter] to type in the widget, if you wanted to stay in single-key mode.
However, if you would like to restore the older, default behavior (as in Axure RP 8), you can go to “Axure RP 9 Beta > Preferences > Canvas” from the main menu, and de-select the “Enable Single Key Shortcuts” checkbox:
Ahhh… Got it. 2 Kudos for you. One for the new feature, and another for allowing old timers to opt back to old behavior. I’ll give those shortcuts a chance to win me over for a while.
