Hey there - have spotted something that desperately needs addressing, thought I’d post here rather than anywhere else - is that the best option @Jane_Axure ?
The Problem
- Create your Adaptive View Set
- Create and ‘adaptive-ize’ a widget
- Convert it to a Master
- Drop that Master on to the page, or any other page with the same adaptive view set
- Cycle through your adaptive views and see how the Master doesn’t adapt along with the page, even though it has the adaptive behaviour for the corresponding views.
Copying and pasting an already working Master (i.e. the one you created from the adaptive-ized widget) works, but is far less than ideal. You create Masters to drag them on from the Masters library.
Can this please be fixed as a matter of urgency?
Also, while I’m here:
How Adaptive Widgets Need To Work
Let’s say I have a Master widget, or widget from a library, that has been ‘adaptive-ized’ with a complete set of widths: 320, 360, 375, 411, 414, 768, 800
If the canvas where this widget is placed has ANY of those views (e.g. just the iOS ones [320, 375, 414, 728])… the widget should adapt as appropriate!
It is so limiting for this not to be the case.
E.g. I want to make a master widget that is fully adaptive, and then make an iOS and Android version of it, and then apply that widget to iOS and Android pages, and it automatically uses the relevant views.
Does this make sense? Surely you can see how this is what should happen?
Great work on the rest of the beta by the way. Lots of overdue no brainer quick wins.
