Stay up to date on the latest beta channel builds of Axure RP in this thread! Please keep in mind that the downloads mentioned here are for beta builds that are still in testing. If you run into any bugs or unexpected behavior, please report them to support@axure.com.
The latest stable build of Axure RP will remain available on our Axure Download page.
Download at Axure | Release Candidate or via Help > Check for Updates (with “Include beta channel builds” selected) in RP
Risk: Medium
Axure RP 9.0.0.3650
- Optimized performance on high resolution monitors
- Fixed OnWindowScrollUp and OnWindowScrollDown on mobile devices
Risk: Medium
Axure RP 9.0.0.3651
- Optimized creation of new team projects
- Fixed freezes when getting large team projects or changes on Mac
Risk: Low-Medium
Axure RP 9.0.0.3652
- Optimized team project operations
Risk: Low
Axure RP 9.0.0.3654
- Fixed some memory leaks on Mac
- Fixed errors opening pages with bad connectors on Windows
- Fixed error running RP on Windows when FIPS-compliant encryption is enabled
- Fixed error nudging vector points
- Fixed fire event action not working from page events in the HTML
- Enabled single key shortcut when using an IME on Windows
- Fixed issues using Korean IME on Windows
- Fixed IME switching to English after opening and closing droplists
- Fixed an occasional error opening files from the welcome screen on Windows
- Fixed copying and pasting an image from Finder on Mac
Risk: Low
Axure RP 9.0.0.3655
- Memory improvements on Mac
- Line spacing field shows the current value even when it is automatically set
- Fixed drag-selecting table cells in dynamic panels and repeaters
- Fixed snapping widgets to a second guide
- Fixed new image thumbnails rendering upside down in image folder libraries on Windows
- Fixed displaced dialog contents on scaled monitors on Windows
- Fixed using flip animations for dynamic panel states via OnMouse events in the HTML
- Fixed setting rich text with strikethrough in the HTML
- Fixed error changing a droplist selection in the HTML on Windows Chrome
- Fixed lines with arrowheads appearing blurry in the HTML
Risk: Low
Axure RP 9.0.0.3657
- Improved performance switching to or from large pages
- Improved performance adding, dragging, and deleting widgets
- Fixed intermittent issues copying and pasting on Mac
- Fixed issues launching Axure RP 9 on macOS 10.15
- Fixed hard crash pasting and optimizing very large images on Windows
- Fixed errors after deleting style effects from multiple widgets at once
- Fixed errors generating Word Specifications with text field interactions or deleted submenus
- Fixed Interaction Editor dialog scrolling to the top after deleting an interaction
- Fixed OnPageLoad scrolling to widgets in the HTML
Risk: Medium
Axure RP 9.0.0.3659
- Improved performance dragging a large selection of widgets
- Improved performance dragging widgets over large sliced images
- Fixed errors opening or generating pages with bad dynamic panel states
- Fixed error pasting widget notes copied from a master
- Fixed error pasting a widget to a repeater dataset on Windows
- Fixed error generating HTML of pages with repeaters that set text on inline links
- Fixed OnPageLoad/OnLoad not scrolling to widgets in Dynamic Panels in the HTML
- Fixed widget property popup showing changes made to the last edited widget
- Fixed images with shadows or filters applied appearing blurry on Windows
- Fixed issue moving Publish dialog between different scaled monitors on Windows
- Fixed bullet points not matching text color on Mac
- Fixed issue detecting a valid subscription when an old lic.key file is in place
Risk: Medium
Axure RP 9.0.0.3660
- Fixed errors when launching RP 9 on Windows 7 and 8
Risk: Medium-High
Axure RP 9.0.0.3661
- Further performance improvements around dragging widgets
- Added more filter options when selecting a target widget
- Fixed libraries not auto-refreshing on Mac
- Fixed inverted shadows when printing to PDF on Mac
- Fixed editing connector points after switching pages
- Fixed switching states on a scrollable dynamic panel causing page scroll on iOS
- Fixed issue setting condition to “Match Any” with a language pack installed
Risk: Medium-High
Axure RP 9.0.0.3662
- Improved performance working in team projects
- Improved performance when updating style properties
- Renamed interaction events for clarity and readability
- Organized interaction events into categories with headings
- Added auto refresh for image folder libraries
- Fixed error closing RP with a scrollable pane popped out on Mac
Risk: Medium
Axure RP 9.0.0.3665
- Organized fonts list to indicate web safe fonts
- Some popular web safe fonts are now included by default
- Added option to renumber footnotes from Arrange menu
- Improved performance when editing location of large groups via the (x,y) fields
- Fixed issue selecting groups when dragging in Select Contained mode
- Fixed [Ctrl]+[Backspace] not deleting entire word when editing text on Windows
- Fixed [Ctrl]+[Shift]+[Arrow] not selecting entire word when editing text on Windows
Risk: Medium
Axure RP 9.0.0.3667
- Quickly switch between publishing to new, existing, or current links in the Publish to Cloud dialog
- Preview widgets when selecting the target of an interaction
- Added bulk selection buttons to the pages pane of HTML generators
- Fixed team projects losing their “Replace Existing Project” ID in the Publish to Cloud dialog
- Fixed interactions and conditions not updating after renaming a droplist or list box item
- Fixed focus issues in the Edit Many dialog for droplists and list boxes
Risk: Low-Medium
Axure RP 9.0.0.3669
- Fixed condensed fonts not showing on Windows
Risk: Medium-High
Axure RP 9.0.0.3672
- Added ability to unassign a submit button
- Fixed team projects reporting connection issues on large team operations
- Fixed errors on team operations after deleting a page or master during connection issues
- Fixed error editing and checking in page notes that use a non default font
- Fixed occasional issue selecting widgets inside zoomed panels on Mac
- Fixed right-click interaction showing the browser context menu in the HTML
- Fixed issues using got or lost focus actions on text fields to target groups in the HTML
- Fixed flow icon not showing for flow type pages in the HTML player
- Fixed widget tables not showing widget text or interactions in specifications
Risk: Low
Axure RP 9.0.0.3673
- Added a maximum height for the dynamic panel editing mode state selector
- Fixed a generation issue when using mixed webfont typefaces on Axure Cloud
- Fixed horizontal scrolling after a dynamic panel state change on mobile devices
- Fixed an issue nudging widgets after renaming objects in the Outline pane
- Fixed lightbox background color not updating in the HTML on Windows
- Fixed an error pasting shapes from the Sketch plugin
- Fixed image fills losing transparency when pasting from the Sketch plugin
- Fixed issues pasting masked images and combined shapes from the Sketch plugin
Risk: Low-Medium
Axure RP 9.0.0.3674
- Default library now includes tooltips linking to widget documentation
- Made canvas scrollbars easier to select and drag on Windows
- Added iPhone 11 and Pixel 4 devices to preset page dimensions
- Fixed interaction editor scrolling to the top after editing conditions or pasting actions
- Fixed issue selecting table cells inside dynamic panels as interaction targets
- Fixed an error opening converted masters nested inside panels and repeaters
- Fixed issues using swipe events on scrollable dynamic panels on mobile devices
- Fixed groups not moving while other widgets animate in the HTML
